Legacy Bootloader issues
The bootloader update described below will help solve the following: Grid Editor disconnects, D51 arch module appears dead, LEDs only flicker for a split second before turning off when module is plugged in.
This issue arises because of an outdated bootloader version, and causes frequent firmware crashes on module boot. This results in modules booting into black LEDs as if the module was off.
All Grid modules in the wild are affected by the outdated bootloader issue, so updating to the current version is strongly recommended!
This update should permanently fix the current issue of modules dropping out/crashing/requiring frequent FW updates and so on. Even so, if you encounter any unexpected behavior, please drop us a mail to support@intech.studio!
Bootloader update step-by-step
- Download the latest bootloader release from GitHub.
- Plug in the module while holding the small button on the side and wait for it to boot with green LEDs
- The module should now show up in your computer's file explorer/finder as the device "GRID".
- Drag and drop or copy the bootloader file to "GRID".
- Now the update should be completed and after that device name should now be "GRID23" instead.
- Grid will be missing a firmware, please use Grid Editor update the firmware of the module.
- After the firmware update the module should boot normally and you're done!
Potential issues after a bootloader update
Some users were reportedly not able to run the firmware update properly after the bootloader update. This caused them to arrive at a similar module state each time with black LEDs.
If you're not able to finish the update successfully, please drop us a mail to support@intech.studio!
