MIDI SysEx
- About SysEx
- Reference Manual Entry
System Exclusive MIDI message Block or SysEX Block for short, change your MIDI Blocks into SysEx mode, where you can both enter SysEx values based on an instrument's specifications or use variables calculated in the Action Chain.
In example 0xF0, 0x41, 0x10, val, 0xF7 val is a variable declared locally.
midi sysex send
- shortname: gmss
- How:
midi_sysex_send(...)- Send 8bit SysEx data bytes (0-255) as separate arguments. eg: (0xF0, 0x41, 0x10, 0xF7)
- What: This function sends a MIDI sysex message when called.
- Example:
